In ORD our files have a 10000 working units. In PowerGeopak they were 1000. What's the best way to reference an older drawing in ORD so that the cells and text aren't 10 times bigger than they should be?
I can turn off the offending layers. I was just using the file for background for staking. I ended up converting it to Civil 3D as it is so much easier to create staking points. I'm going to try to recreate the points in ORD to see how difficult the process is.
Thanks for the help and the insights.
