Openroads Viewing Sheet Boundaries Alongside Clip Shapes/ Named Boundaries
Hi all,
I am wondering if there is a way to view sheet boundaries alongside with the designated named boundaries/clip shapes on openroads.
For context, I have about 350 named boundaries that I can display in a single master file. I just want to know if there is a way to display the sheet limits in the same master file. I'm adding annotations to a single master file for these sheets, and I need to know the limits of the sheet for each named boundary to figure out my limits for annotations.
  • As you mention the named boundary acts as a clip shape to create the drawing model, then that drawing model is attached to the sheet model. So the only elements that show on a sheet model are what is inside the named boundary shape back in the design model. Since the named boundary shape is the limit of what shows on the sheet, and you can use it to base your annotation placement on.
Reply
