Is there a way to tell if the "Last Valid Value" was used?
Example, I have a cell with an item type that reads an alignment and populates the Station and Offset when in ORD. If that file is opened in MSCE and the cell is moved, the station/offset will not be updated (as expected) and the "Last Valid Value" is displayed. Is there a way to know this?
The problem is that a user could move the cell in MSCE and not know the value is not correct / up to date.
I think the answer is no. From a workflow point of view it would be best not to provide MicroStation users with edit access to OpenRoads DGNs.
