WorkSet disappears
no WorkSet - OpenRoads Designer 2021 Release 1 - Have anyone got a problem when after opening file shows up a window with information no workset and then everything is closing down and I can't open a file again? What should I do?
  • No Workspace AND No Workset should able to open the OpenRoads without loading any DGN libraries. Hence. you can select Workspace "Training and Examples" and any workset to start the OpenRoads Designer..
    If you cannot find any workspace, most likely the installed workspace configuration is removed. You can check here as default:path:
    C:\ProgramData\Bentley\OpenRoads Designer CE 10.10\Configuration\
