Would anyone have an example or a video of how-to setup different batter conditions between different strata levels?
Hi Steven,
One method would be to create an end condition that targets the substrata terrain you have and then set up the priorities you want it to search for:
Add New End Condition Component (bentley.com)
Understanding End Conditions - YouTube
Mark
thanks Mark,
would you have an example of what this would look like?
Hi Steve, the top link shows the actual panel in the Template Library Component where it is set and the 2nd link video goes through how it all works. Hopefully that gives you what you need to set it up.
