can anyone please help me on importing super elevation table exported from civil 3D to OpenRoads. can we directly use the excel file we exported from civil 3d import to OpenRoads??? Do we need to convert into any required format for the import??
Hi Vimal, run superelevation report in ORD and select CSV report. This will give you the format you need to prepare your civil 3D exported superelevation data. I've done that in the past so it's doable.
