Does anyone ever run into the issue with ORD GC 10.11 that the file becomes read-only when opening the exact same file again?
Basically I did my geometry and data extraction in a new file that started from a 3D seed, saved the file and exited. When I opened the same file again, the error message popped up and saying the file is read only.
-Wayne
We see sometimes when you copy elements in from another file it will bring over the civil data/rules/file schema. I wonder if you use Microstation Connect it will just bring the graphics you need and you could export/import the geometry via XML.
I dont think this has to do with copy elements. since all I did was setting up my nodes and save / exit the DGN. And the next time I open the same file, it has that error message and becomes read-only. When the file is in read-only, i dont even see any of the nodes since the graph panel is no longer available.
