In OpenRoads Designer CE 2022, when using the "Create Template" feature, if there is no visible representation change in the component's feature definition. Why isn't the visual representation changing?
Please check if Element Templates and Levels are loaded from libraries. Does it happen in all Workspaces?
Also, try to create a corridor, assign a template and then edit the template in place, I have some files where after doing this, the colors are back. Then you can open the Template from the itl with colors.
