Is there a way to create a file that just is a sheet model with the drainage plan and drainage profiles? The workflow for the FDOT workspace has the sheet within the model dgn but i am having issues with crashes during modeling that ends up corrupting both the database, drawing and sheets. I would like to keep everything separate in the event of a crash, resheeting these files is becoming quite an issue.
The sheets have the plan views, profiles of pipes, and tablature data in them
Emily
The FDOT drainage plans dev guide may be outdated (using 10.08 last I checked). There have been performance enhancing improvements to block databases from copying to other files since then that may have changed their direction. You should reach out to FDOT directly. Since FDOT uses some of their own VBA tools, you'll want to run any changes to that workflow by cadd.support@dot.state.fl.us They also have a FDOT group here on the forums.
colliersengineering.com
