ORD Earthwork lines connectin Existing Ground surface in hapazard way
I found that for particular section of the Corridor, the Earthwork lines are connecting in hapazard way to Existing Ground surface.
Same Template generate Earthwork lines in correct manner for other section of the Corridor.
OpenRail Designer CE 2022 Release 1
I have markked the problem in the attached pic.
What may be the reason for this??
Babulal
