ORD Target Aliasing doesn't work properly
Hello, everyone
I have a problem with Target Aliasing function in ORD corridor. I created a liner corridor which need to intercept with other corridors. I used Target Aliasing to target the referenced corridor, but after running the function, the corridor was not target properly.
Could you help me find out why the liner corridor doesn't slope to existing topo properly as before?  Thank you so much.
