Why is the 2nd alignment not applied?
I'm currently doing a road model, but in the case of photos, is it like that because there are a lot of 2nd alignments? 2nd alignment receives point control of 1 curve and 2 straight lines in the same section, but even with the 2nd alignment function turned on, there are parts that are created parallel to the original line.
Or, since the two lines with the 2nd alignment function on are straight, is it not possible to drop the template according to the curvature between them?
(ver openroads designer CE 2022)
