Hello.
In the ORD survey flow, is it possible to have 2 alphanumeric codes in 1 feature definition?
In PowerCivil SI you could include several codes for a single entity
Thank you!
In our workspace, we added the code to the end of the separate feature definitions. For example, we have two codes for lip of gutter (LG and LOC). The two feature definitions are "X-Curb And Gutter Lip_LG" and "X-Curb And Gutter Lip_LOC". I couldn't find a way to add two codes to the feature definition.
You can add more than one Alpha Code to a "Survey Feature" it is just a coma separated list with no spaces.
Mike LongstreetVermont Agency of TransportationCivil Engineering Technical SupportVTCAD Help
When I mentioned CSV, i was abbreviating Comma Separated Values. So as Mike states, you could use LG,LOC in the Alpha Code field, but that assumes only one of the two Feature Definitions gets applied that set of Alpha Codes.
Thanks, Mike!
I have included several codes:
this is the .txt:
this is the result:
Thanks for sharing, sharing is living!!
