Hello.
In the ORD survey flow, is it possible to have 2 alphanumeric codes in 1 feature definition?
In PowerCivil SI you could include several codes for a single entity
Thank you!
Thanks, Mike!
I have included several codes:
this is the .txt:
this is the result:
Thanks for sharing, sharing is living!!
Thanks for the information. I wasn't aware of this capability and it would have saved me from creating so many feature definitions.
Hello Bob!. If you work in construction, you can take advantage of "duplicate" entity definitions to differentiate between existing elements and new construction elements. When you do a topographic survey of the construction zone, sometimes you register old elements and other new ones in the same topographic and that are of the same materials. You can link a level to a definition of old asphalt and another level to new asphalt. It's an idea. Health
