On an interstate reconstruction job, we had previously created cross section named boundaries about the Survey Centerline for the mainline.
As the design progressed the original survey centerline was modified. The overall alignment changed very little (extended both east and west) and the stationing in the areas of the Named boundaries did not shift.
However, the original alg that the cross section named boundaries were originally created about, was subsequently deleted, and replaced with an updated Survey Centerline.
The named boundaries still contain the naming convention based on the survey centerline stationing (i.e. STA 1047+00), however when reannotating the drawing models, the stationing does not annotate. I believe this is bc the original alignment that the cross section named boundaries were created about was deleted, and therefore the named boundaries are no longer associated with an alg.
Is there a way to re-assign the named boundaries to the updated survey centerline alg, so that the stationing will annotate?
Stephen,
Did you try and run the reattach corridor command as described in this video?
Video: Corridor Reattach - OpenRoads | OpenSite Wiki - OpenRoads | OpenSite - Bentley Communities
HTH,
Gerald Piotrowski
