The following dialog opens when I try to invoke utility properties for a sanitary pipe in Drainage and Utilities -- all reference files are turned off, the features are live in the active file. Any help in this regards would be most appreciated. . Thanks.
I am having this same problem except with a storm drain system. Any help would be appreciated.
Since 10.10, by default, loading of referenced drainage databases is disabled.
https://docs.bentley.com/LiveContent/web/OpenRoads%20Designer%20Readme-v14/en/GUID-9CA386EA-84C2-4D4B-A6D9-8719E410B13F.html
But main drainage properties are still accessible since attached directly to the links and nodes, see
https://youtu.be/XPuEioGPX_w?feature=shared
Vincent RAULT [Bentley]
