Quadrant Bearings using Civil Accudraw or Accudraw?
ORD Geometry builder includes the use of quadrants to speed up bearing inputs.
when switched to "Bearing" will show as follows:
Can this same format be used in civil accudraw or accudraw?  Quad#Deg.MinSec.
Are there any settings to be able to change accudraw to match input concept used in geometry builder?
Geometry Building only needs the quad number 1-4 and "One" period to separate the degree from min/sec.  Straight forward and simple.
Solutions appreciated.
