I requested additional survey to be done for me project. The surveyor added the csv data into the field book for my terrain file. This caused my current vertical profile to be dramatically shifted from where it should have been. Is there a way to avoid this? Did the surveyor mess up when importing the data? was it because the vertical alignment was ruled/snapped to the terrain that when new data was added behind it the whole profile moved?
Originally the vertical profile was only over the terrain section to the right. When that left chunk was added (additional survey imported) it stretched it back to the left.
It should only be over this section. It was snapped to the original ground when I had placed it.
I just ended up getting a recovery file of the terrain before it was added. This is what it originally looked like.
Answer Verified By: Christian Orr
