Hoping this question is a fairly straightforward one but I haven't found a solution online. I'm trying to make my proposed terrain match the existing terrain at the boundary of the proposed work. What's the best way to accomplish this?
Thank you!
How are you generating your proposed terrain? The method used may determine the solution. Please be as descriptive as you can.
Which version of the software are you using? Specific version numbers (10.xx.xx.xxx) are most useful.
MaryB
The proposed terrain has been generated using contours and a boundary. I will also be adding a few corridors at some point.
I've been using OpenRoads Designer 2022 R1 10.11.00.015.
I assume that using contours means you created several independent features, each with their own profile. If true, you can simply add the boundary to the proposed terrain. If the profile of the boundary is set to the existing terrain both will use the exact same elevation.
Jan,
Yes, your assumption is correct. I figured this would involve the boundary. My boundary is currently included in the proposed terrain, but it is not set to the elevation(s) of the existing terrain. Is there a method to accomplish this?
Kevin,
You mention the boundary is part of he proposed terrain. Does the boundary have a profile? If not, this is where you set it to follow the existing terrain.
To set the profile of the boundary to the elevations of the existing terrain:
