Combination of alignment and existing surface in Profile
I have an alignment whereby I need to use the existing surface at the start and the end of the alignment, but modify the middle section. Now, I have created a complex vertical element which is fine, however you then have to assign a feature definition to label the section that has been modified. This leads to all sorts of problems with the points on the existing surface being treated as VPI's and labelled.
Also, has anyone got a quicker way than slicing and dicing the existing surface to create a profile? It used to be that you could drape the whole alignment on the existing surface, and then apply vertical geometry which would override the existing surface from CH xx to CH yy. Now, its a case of trimming which not always works well.
The attachment shows the problem at the end whereby the section that is draped on existing is being labelled with VPI labels.
