Divider Line for Stationing using Civil Labeler Not Showing Up in Sheet View
Wondering if anyone else has come across this issue. We have some station/offset callouts in a drawing that were created using Civil Labeler in OpenRoads, and when in sheet view, the divider line in between the values does not show or display. Not sure if the issue is based on the class properties of the element (currently set as primary), or if I need to change a setting within Line Style, Weight. It shows up correct when in Image 1, but in Image 2, you can see that the divider line is missing for the callout. It shows up fine in OpenRoads, but not in MicroStation CONNECT. Is there a reason for this difference?
Image 1 (divider lines shown)
Image 2&3 (divider lines not shown)
  • Image 1 appears to be a screenshot, while images 2 & 3 appear to be printed output. If the issue is only when printed, then you need to look at the settings files (plot drivers, design scripts, pen tables, etc.) to see if there is a clue why it shows on the screen but not when you print it.
    MicroStation and ORD do not use the same resources by default. It is possible to point them to the same workspace/workset files, but they do not automatically look in the same places. While I can't think what could be different specifically, it is possible there is something between the two setups that is defined differently.
    What version of ORD and CONNECT are you using? Specific version numbers (10.xx.xx.xxx) are the most helpful.
    Would you be able to send us a small example DGN? without your full set of resources, it may be difficult to track down, but there could be a clue.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
  • Thanks Mary. We're using the following versions:
    -MicroStation CONNECT (10.16.01.056)
    -OpenRoads Designer CONNECT (10.10.21.4)
    And I will work on getting a copy/example of the dgn it can be reviewed. Will provide an update shortly.
  • I have seen this.  It always happens when I use the Civil Labeler Text Divider.  The divider never appears when the file is opened with MicroStation along.  This is how it has been for some time now.  Images below are from the same file, same workspace, same note. One with OpenRoads 10.12.01.4 the other with MicroStation 10.17.02.61.
    From OpenRoads
    From MicroStation (same file same workspace)
    Mike Longstreet
    Vermont Agency of Transportation
    Civil Engineering Technical Support
    VTCAD Help
Reply Children
