We have a live nested collector file attached to a working file and are unable to manipulate the levels. I am thinking this is a workset/workspace configuration setting done by the Prime..
Does anyone know how we can adjust this?
Thank you,
Carley McDermott
GEI Consultants
I believe that is controlled through your configuration.
MS_LEVEL_EDIT_NESTED_ATTACHMENT_LEVELS = 1
Should do the trick.
MaryB
