SmartObjects MVBA to rotate cells in OpenRoads Designer is not working. When I detail the survey shots I can see the information for the macro is attached, but when I redraw nothing happens.
I would ensure:
See if the points rotate after making those adjustments and hit the redraw command.
communities.bentley.com/.../video-using-vba-to-rotate-cells-for-points-in-openroads-survey
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
Answer Verified By: John Sloane
I was attempting to rotate to an alignment. I did not realize it had to be an element in the field book.
