<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>ORD - TrimbleLink - Defining temporary DC / XNF File location.</title><link>https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/246840/ord---trimblelink---defining-temporary-dc-xnf-file-location</link><description>When importing a *.job file into a FieldBook using TrimbleLink, ORD creates a *.DC file and a *.XNF file both located in a temporary folder on the local PC @
 &amp;quot;C:\Users\USERNAME\AppData\Local\Temp\Bentley\OpenRoadsDesigner\10.0.0\SurveyTools\TempLoadData</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: ORD - TrimbleLink - Defining temporary DC / XNF File location.</title><link>https://communities.bentley.com/thread/770785?ContentTypeID=1</link><pubDate>Fri, 23 Jun 2023 13:08:02 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:641bb4e1-4869-4d5e-aca2-9a0d44fa7216</guid><dc:creator>Peter VALLIERES</dc:creator><description>&lt;p&gt;I have figured out that there is no need for this.&amp;nbsp; The temporary DC file that the operation creates is only used to write the data from the job file to the actual DGN.&amp;nbsp; &amp;nbsp;The actual DGN contains all the information and as long as you keep the data file in the Fieldbook,&amp;nbsp; it will &amp;quot;follow&amp;quot; the DGN file.&amp;nbsp;&lt;br /&gt;&lt;br /&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
