cannot edit the line string z value from the segment list in Openroad Designer/ MicroStation.
after creating a line string, from the properties if select the segement list. I am not able edit he z value.
My task is to creat a simple 3d line with different elevation of vertices.
This was available in BRT.
Please look the screen shot attached
Parents Reply
  • Hi Jing
    Thank you for the response.
    in your solution you are changing the elevation segment by segment (start and end). And this is useful for a line which has few segments/vertices. But this will be time taking with a  line having 100s of segments/vertices.
    Previously in the  BRT we had segment list as shown in image below,  where we can edit th elevation very easily and it work like simple table and very fast to enter the data. This Table editing is disabled in the new microstation /openrail /openroads.
    Is there any way we can activate the editing in the segment list.
