I use the Place Table tool to insert tables from Excel and so far it's worked how I would like it to. I've recently run into an issue where the formatting of the cell widths/heights in ORD isn't the exact same as what they are in Excel and text in the ORD then becomes spread out. I've been manually changing the width/height of the cells to get around it but that's too time consuming. Is there a way I can fix this in the settings? We are also trying to move away from Axiom.
Any help would be appreciated!
