I have moved my horizontal alignment annotations to avoid overwrites in Plan Production, but when I modify my vertical alignment; the horizontal alignment annotations revert back to the original location.
Is there a way to disassociate the PC, PI, PT, curve data, etc. annotations from the horizontal alignment . In InRoads, I would use "Remove User Data".
Hey, Mary! Per our DOT, we are using OpenRoads Designer CE 2021 Release version 10.10.1.3 at the moment.
In my experience, you are best off dropping and copying in the annotation. Otherwise, you will be constantly battling with it. You could review a whole set of plans and get it looking perfect then come back a month later and everything has moved.
