I just discover that you could use Transverse alignement to annotate cross slope!
You just need to have alignements (only alignement, its not working with linear feature) with profiles (proposed or existing) and linear 3D annotation groups and you can have result like this:
all dynamic, so if you change your profiles all the slopes updates!
Thanks for sharing!
Hi Jeremie, Thanks for sharing!
I tried to make an annotation group with the flow arrows. Unfortunately I can't get it to work. Would you like to share how you created those flow arrows?
Regards Louis
yeah sure:
its' the placement point that is important
Thank you Jeremie!
Thank you for sharing your findings here, Jeremie!
Mark
