I just discover that you could use Transverse alignement to annotate cross slope!
You just need to have alignements (only alignement, its not working with linear feature) with profiles (proposed or existing) and linear 3D annotation groups and you can have result like this:
all dynamic, so if you change your profiles all the slopes updates!
Great stuff, let's not stop pushing for this functionality in Civil Labeler though!
Mark
actually, it works in Civil Labeler for linear elements with active profiles.
We use either create transverse alignments or just manually placed lines and profile from the surface (bulk for the selection set) and then we select all element to annotate slopes along and run Civl Labeler on the selection set. Text Favourites we have differs alternative slope annotation over 10%.
Adam,
What text favorite are you using to get a slope between points like you show above?
Marc
I see you are using the Linear3d Annotation.Point Slope text favorite. From my recollection this onluy works on 3d linears in a 3d model. In order to do this you must have a 3d model and label in the 3d model. Is that correct?
