corridor definition in ORD 2022 R3
In my Corridor, the feature definition of the corridor was set to no design at first. When I almost finished the model and changed definition to the design in the library to get the Top Mesh side of the road model, all the settings adjusted to the Vertical Alignment of the model were released and the model was ruined. Is there a way to make sure that settings such as Second Alignment and Point control do not change arbitrarily even if the definition of the corridor is changed?
