I am trying to generate reports of the lane lines and the edge of pavement lines off of the centerline at 25 ft intervals and not having any luck. I am using ss 10 with open roads technology.
Station Base Report should do the trick...
Then change the report to list proposed EOP elevations.
colliersengineering.com
The mentioned reporting tool will ask for two selections (two steps). You can either select a profiled 2D graphic both times OR select your Corridor's alignment 1st then the EOP linear feature next (Tool prompt will say Locate First Offset Element). However, if you don't see 2D Linear Features being made by your corridor, check the properties of your Corridor Design Stage. If Linear Features Display option is set to False, you may not get the ability to select that 2D EOP graphic produced by your corridor. The report tool will also allow selection of the mentioned EOP graphic both times, but will start at zero and not report the stationing used by the corridor (ie. Alignment selected during the first prompt). To get a better idea how the tool works, here's a video (but not in the context of a corridor). https://www.youtube.com/watch?v=DbRVp-6vEH0
Answer Verified By: Paul Pare
No luck. I am using this version see image. This is a old project and I tried to convert to version 2022 r2 and its not compatible. I cannot see or select the 2d feature, not sure how to display it in this version. I can select the LT_EOP in the 3d view but the report is not correct? I get all kinds of random stations and the elevations are at the center line not at the LT_EOP?
V8i still has access to corridor design stage standards under "Civil Standards" and "Project Settings" (File dropdown menu > Project Explorer). You may need to switch the design stage to one with the setting enabled. Also change the report to the one highlighted below to get elevations based on intervals.
