Vertical geometry
I am a bit new to OpenRoads designer and kindly need to know what exactly the aim is for creating a vertical geometry to be able to create cross sections afterwards. In civil 3D for instance, it is enough to create an alignment through a certain surface and then create cross sections to include the elevation data of this surface. When I am trying to do the same in ORD by drawing a horizontal geometry, I notice that, the alignement is not located in the same level as that of the surface which I wanna include in my sections. Is this then the purpose of drawing the vertical geometry in ORD, that is to adjust the levels of the alignment?
Many thanks,
Mamdouh
Parents Reply Children
