Snaps not snapping - Interactions between civil geometry and MicroStation geometry
Hi All,
I'm new to using ORD and I'm trying to learn how all the stuff works. Today I encountered some unintuitive behavior with interactions between civil lines and not-civil lines. I was trying to trace overtop of a MicroStation line with a civil line so that I could test making a profile for a curb ramp. I noted that while I could snap to both ends of the line segment upon first drawing the line, If I subsequently moved one of the ends of the civil line off of the MicroStation line vertex I could not snap back onto the MicroStation line vertex. After a few more minutes, I was able to with some very inconsistent "press and hold" with the mouse over the civil line vertex, and sometimes the Accudraw compass would appear?
The behavior is very bizarre and inconsistent. It makes me think there are incompatibilities between the two types of lines, or between civil lines and the different versions of Accudraw.
Any tips?
OpenRoads Designer CE - 2021 Release 2 - Version 10.10.21.04, Using RealDWG 2022
Parents Reply Children
