Surface Modeling Obstructions
I have built an approach/departure surface for a helipad and I also have a drone survey of the area. What is the best way in OpenRoads to build an obstruction surface so I can see where trees are penetrating through my design surface?
I tried using the delta surface but it only gives me a huge area where both surfaces are present. What I am looking for is small clouds where I know a few trees are penetrating the surface.
