I have orthographic imagery referenced in my Open Roads Connect .dgn that I need to get out to a DOT that is still using InRoads ss2. The .tif's display properly in Open Roads but when both referenced or attached through the raster manager into ss2, an error of "unsupported file type, error 13" is thrown. Can a .tif file be "too new of a version" for an older software such as ss2 to recognize. Is there a way for Open Roads to export out that attached imagery to an older .tif version that ss2 could then recognize?
Maybe you can try save as new GEOTIFF format with the "Compression" as NONE being help.
The setting is under Save as "option"
