Hi Users!Can someone help me with the Grey out issue in Openroads. While using a specific workset the Openroads 10.10.21.04 version the screen is grey out.It was working file earlier and I'm unable to resize or move or maximize it. While other worksets are working fine.
Thank you in advance!
Try to run -restoredefaults for the OpenRoads Designer
Restore MicroStation to Factory defaults
Answer Verified By: Shivam Gupta
Thank you so much Jimmy!It worked :)
