Single vertical profile for alignment that has multiple breaks and segments
Hi all,
I have an alignment laid out for a shared use path I am designing. There are several "breaks" or "discontinuations" along the path due to intersections and crossings. I would like to have one profile associated to this alignment, but the grading for the actual path is broken up in multiple segments. Is there a way to complex the profile so all segments are just one entire profile? Hopefully I explained my question well enough for someone to help. Thanks!
  • Aaron,
    I am not aware of a way in which you can have any discontinuities included as a single element. A couple options I would propose. one is to simply model the profile across the intersections as that is what the profile is actually doing. A second option would be to split the alignment at the sections if you want to treat them separately. I am not sure what your specific motivation is for the single profile, I suspect for modeling in which case the latter may not be a desirable solution. A final proposal would be to use a construction element Feature Definition and create a single profile using 0' offset from each of the segments and connecting them with either a sampled surface from the intersection content or simply lines. That would allow the use of the profile for modeling purposes and display of the individual "segments" within a profile view.
    Hope that helps.
    Steve
    Steven Litzau, P.E. - Senior Consultant
    www.envisioncad.com
    ORD - 10.12.02.04 / 10.10.21.04 / 10.10.01.03 / 10.08.01.33
    Power GEOPAK / Power InRoads - 08.11.09.918
    Civil 3D - 2021 / 2022
