Why do the drainage properties of my individual inlets not follow what I set in the prototypes for that inlet. In particular design settings don't seem to follow through for desired sump depth, conduit cover at node (minimum) (ft). It should be noted that I am using 2021 release 2 version 10.10.21.04.
I was able to set my spread for inlets and pipe slope globally through that dialogue box but it doesn't seem to have the capability to apply the global standards to conduit cover/depth below invert. If it works for you let me know thanks!
