I'm trying to import an landxml file I exported from SewerGEMS into ORD and I'd like to assign a specific feature definition I created (still under StormWater) to them when I import them in. Is there a way to set that?
Right now there's no feature deifnition when it was brought in and in the drainage property it is default to TxDOT RCP Class III - Circle. Can I change that default setting to be something else?
Thanks!
Hi Lorraine,
If you’re not having any luck, one option to consider is using the ModelBuilder function within ORD to import the drainage network from a spreadsheet.
It enables a network developed in another software to talk to ORD by allowing you to map a network, or just a portion of it, to a particular feature definition.
Link for more information: Video: Introduction to ModelBuilder and Importing data
Ashwin
