Corridor Mesh to DWG Solid
I'm trying to convert some corridor meshes to workable 3D solids in .DWG.
I tried using the command ''Convert to Solid'' but this didn't immediately work. Browsing on the forum I found some threads suggesting to remove the data from the file by using the Fence command in the 3D view.
After trying that I got the result I wanted (a complete solid from a Corridor Mesh), HOWEVER, this only worked when the corridor was built using 1 single template. The corridors where I need a Solid from are all built from multiple template drops that are closed (no gaps between meshes).
After splitting the meshes, I tried the Convert to Solid again but it wont work anymore :/
The weird thing is: after splitting the Corridor mesh into small parts (ca. 2m) the Convert to Solid command DOES work, but only on the first mesh (see image)
(before command)
(after command)
(second mesh before command)
(second mesh error code)
Does anybody know why this happens and/or how to fix it so I can export a corridor made from multiple template drops to a 3D solid in .dwg?
Parents Reply Children
