Modify Line Style Attributes
I want to edit the line style of traffic cones. I know I should work with the "Modify Line Style Attributes" menu in Microstation Connect. I was looking for a complete video or tutorial on this. What I want is to change the spacing of these traffic cones from for example 100' to 75'.
  • Depending on how accurately you need to see your cones...you could apply a Linestyle Scale, either before placement through the LineStyles dialog, or after through the Properties dialog. If your standard linestyle scale has a gap of 100', you could apply a linestyle scale of 0.75 to see your cones at 75'. Unfortunately, the cones would also appear to be 75% of the standard size.
    Also, you could look at the "gap scale" in the Modify Line Style Attributes dialog. I don't know that I've ever gotten it to work the way I expect, but I don't need it often enough to dig into it. Modify linestyle gap scale may allow you to change that gap spacing without affecting the cone size.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
    Answer Verified By: Sina Famili
  • Thanks MaryB, its nice of you. Yeah I tried that and worked
Reply Children
