• Hi Frank,
     Is this within the InRoads or GEOPAK Survey module?
     Alan
  • Yes, I'm asking for InRoads Survey!
    frank
    Frank
    since 1985: GIS, CAD, Engineering (Civil)  Senior Consultant : [Autodesk Civil 3D , Esri ArcGIS, VertiGIS: in previous days : Bentley MS V4 - V8i, GeoGraphics, Bentley Map V8i, InRoads,  HHK Geograf, IBr DAVID] :  Dev: [C, C++, .NET, Java, SQL, FORTRAN, UML]
    [direct quote by: http://en.wikipedia.org/wiki/Helmut_Schmidt]: "Wer Kritik übel nimmt, hat etwas zu verbergen"
    Wer Grammatik- und/oder Rechtschreibfehler findet, der darf sie behalten :-)
  • What format is it looking for?
    We were able to make code lists for Carlson and TDS using the XML Reports and there is another format delivered with the product.
    There are reports in the XIN and Survey folder of the XML Reports that work with the XIN file. Open the browser and use the File Open menu to select the XIN file. The filters dropdown have a *.xin file in the list.
    These reports can make a CAD Managers job much easier as you can see very quickly data on multiple preferences, styles, named symbologies and more. You can copy some of the delivered reports and make new ones to list almost anything you want about the data in the XIN file.
    Charles (Chuck) Rheault
    CADD Manager
    • MicroStation user since IGDS, InRoads user since TDP.
    • AutoCAD, Land Desktop and Civil 3D, off and on since 1996
  • caddcop:
    Hi caddcop ,
    I'm not looking for a report style.
    Leica Total Stations Series 1100 and 1200 have an own format for survey code lists.
    And I like to know if it is possible to export my survey codes out of Inroads Survey to that specific file type. An the Leica Code Lists are binary not xml or ascci!
    Frank
    Frank
  • Almost all of InRoads exporting is done with reports. The source for the reports is almost exclusively XML.
    Reports in turn, export ASCII, HTML or XML. Reports can do this from various points within the product. InRoads Survey Codes are store in the XIN file - which is XML and certain report style sheets can convert them to ASCII, HTML or XML.
    Unless the TPS or some software it uses supports importing codes in ASCII, HTML or XML, I suspect you are out of luck. You probably need to contact Leica to see what they recommend.
    CADD Manager
