Greetings,
How to create Annotation Cells in ORD 2022 r3, where there is no option of XML files. Is there any configuration variable need to set prior to create Annotation cell.
If any one can record a small video in ORD 2022 r3 it will be really helpful.
Ilyas
Information on how to enable Annotation Cells can be found here:
(+) What is an annotation cell? - MicroStation Wiki - MicroStation - Bentley Communities
With the later versions of the products (MicroStation, ORD, etc.), the Properties has just been moved to a different dialog, but still operate the same as before. The setting you're looking for would be toward the bottom of the Properties page:
communities.bentley.com/.../import-export-annotation-xml-file-icons-missing-in-open-roads-rail-site-designer
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
