reference will only attach files in current folder
We are having a strange occurrence. When attaching a reference to a dgn file outside of the current folder ORD will be attached the wrong dgn.
For example, we have a drawing named topog.dgn. When trying to attach to a different "topog.dgn" file from a different project- after the file is selected in the ref dialog box and you select ok. The reference is created to the open topog.dgn file.
Has anyone else had this problem?
We are using OpenRoads Designer ED 2022 R1.1. (10.11.3.2)
Parents Reply
  • When a CADD Standard create problems, it is time to revisit those standards. Unique filenames are possible with not a lot of work. All that needs to be done is to add a project identifier to the filenames. With Open Roads files being both CAD files and design data containers, we even added a corridor name to our standard file names, All files within a project get a project ID associated with them and are part of the filename and when a file contains design data, if it is specific to a particular road in the project, we define a "corridor" name, to be used for alignments, superelevation, corridors, terrain elements and more.
    This way, reference filenames are always unique per project and referencing files across projects are never an issue.
    Charles (Chuck) Rheault
    CADD Manager
    • MicroStation user since IGDS, InRoads user since TDP.
    • AutoCAD, Land Desktop and Civil 3D, off and on since 1996
