We are having a strange occurrence. When attaching a reference to a dgn file outside of the current folder ORD will be attached the wrong dgn.
For example, we have a drawing named topog.dgn. When trying to attach to a different "topog.dgn" file from a different project- after the file is selected in the ref dialog box and you select ok. The reference is created to the open topog.dgn file.
Has anyone else had this problem?
We are using OpenRoads Designer ED 2022 R1.1. (10.11.3.2)
the product was designed that way [don't shoot the messenger ;-) ] - it has always done this.
It just seems strange that a project would have files of the same name. I can see naming conventions IE: Border, Topo, etc... OR even letter designations for different disciplines.
but having files of the same name in one project, I wouldn't consider a very good practice.
Timothy Hickman
Main: 877 627 3772|
I don't think we're on the same page. I've used Bentley products for 15 years and never had this happen. You choose a file to reference, and it attaches regardless of the file name or location it is saved.
We do not have the same named files within one project, I agree, that would be bad practice. Cheers!
I was just stating the way the product works. Unless I am missing a step in what you have explained.
You have two files of the same name and the issue is that one of the files is either the open design file, or exists in the same folder as the open design file. I cannot tell you why you have never encountered this previously, only why you are encountering it currently.
I hope this helps in determining a workaround or a workflow going forward.
just trying to help.
In this article at the bottom is the order in which the reference is searched:
Understanding File Locations And Reference Attachments In MicroStation
Your search is getting to step 4 before the final step 5 of the full path of the reference.
A possible work around might be defining the MS_RFDIR variable to include the folder containing the reference so it is found before the "current" directory ? or attaching the reference using a variable ?
Possibly! I'll check into that variable. I appreciate your help!
