We are having a strange occurrence. When attaching a reference to a dgn file outside of the current folder ORD will be attached the wrong dgn.
For example, we have a drawing named topog.dgn. When trying to attach to a different "topog.dgn" file from a different project- after the file is selected in the ref dialog box and you select ok. The reference is created to the open topog.dgn file.
Has anyone else had this problem?
We are using OpenRoads Designer ED 2022 R1.1. (10.11.3.2)
That helps. OK, maybe it doesn't because PW manages the environment so well, but it does mean I can help troubleshoot a bit more.
Is MS_DISALLOWFULLREFPATH set/defined?
MaryB
That is Correct!
MaryB that variable is not defined.
ok
The Bentley products will resolve/find the file located in the same folder as the active file first (which is what you are seeing).
The best way around this is to not have the duplicate names.
Timothy Hickman
Main: 877 627 3772|
For a workaround, yes. CADD standards dictate the file naming convention so long term that isn't an option. Luckily it is only this one project. I just can't figure out WHY it's doing this. So irritating.
Thanks for the relies!
