Attribute survey setting to fieldbook?
(ORD 2021 R2)
We have a situation where we have two different data collectors in our organisation (X and Y).  Each data collector has its particularities and each has their own survey settings within our Survey DGN library to properly create linework, link codes, string replacements etc.
It happens that two teams survey the same project with different data collectors.
When starting from a fresh drawing,  if you create a new FieldBook, ORD will ask which survey setting you want to use.   However this is only asked once.  If we create a second fieldbook within the same DGN file,  ORD will default to the prior survey setting selection.
Is there a way to configure the survey setting to be applied to a particular fieldbook so that within the same drawing we have FieldBook1 using X_SurveySettings and FieldBook2 using Y_SurveySettings?
P.
