Hi, OpenRoads Community.
I need to move the location of the Search Ribbon window (the tiny one at the upper right corner). It cover the end of the file name that I'm viewing, which is crucial for me to check to make sure I opened the correct file.
We're collaborating with a few companies for a big project. Being able to see the file name is so important because file names show different discipline.
Does anyone know the answer to this simple question?
Thanks.
Yoko
I think the ability to move, turn off or resize these would be a nice GUI feature.
Jan,
Thank you for your reply. Since we haven't figured out ucf and upf files for the ORD, this isn't a quick solution for me. But, I'll keep this option in mind Thanks again.
Shawn,
The first trick already solved the issue and I'm so grateful that I can see the file name so easily.
Thank you also for showing other ways to see the file name. That comes handy.
Thanks again!
I wanted to clich Verify Answer under your reply, but after I click it, it disappeared and it still says 0 answers above. Can you somehow verify your reply as 'Answer'? Thanks.
Yoko:
My page here shows that you have indeed verified Shawn's answer. Good stuff- BTW- Shawn!
Best Regards,
Mark
