Hi, OpenRoads Community.
I need to move the location of the Search Ribbon window (the tiny one at the upper right corner). It cover the end of the file name that I'm viewing, which is crucial for me to check to make sure I opened the correct file.
We're collaborating with a few companies for a big project. Being able to see the file name is so important because file names show different discipline.
Does anyone know the answer to this simple question?
Thanks.
Yoko
It looks as if OP is running through ProjectWise. That's where I recognize the variable dialog from. Some PW admins allow CFG variable edits and others don't.
MaryB
As for the full path variable while running in ProjectWise, we have turned it off in our datasources as it was showing the working directory path and not the PW path. But PW paths are notoriously long and would often be too long to be useful anyway.
