the point lost control after add the Secondary Alignment in version of 10.11.00.115 ORD
Good day! Bentle Support Team,
I got an problem while I am running the Highway Gore Area design with the new version ORD (10.11.00.115).
At the ramp gore area, we must force the ramp outer edge perpendicular with the inner edge. Thus, we use the function of Secondary Alignment to achieve it.
But in the new version, it is no issue if the template is simple. For instance, we created the top surface at beginning to run the supperelevation and point control. it looks fine. (see the snip 1)
After we developed the template to add more constraint and rules for the base and grading design, the issue comes up. the ramp outer edge lost association with the point control (supperelevation and Hor..). There is small discrepancy between the control what we expected. (see the snip 2)
If we turn off the function of the Secondary Alignment, the point control will bet back, the points will be associated with the point control properly. (see the snip 3)
the function of the Secondary Alignment has been used for the ramp gore area control normally. we don't have issue before.
I would appreciate it if you could take a look at my case any help us fix this problem. Thanks!
Best Regards,
Kenny
